Good afternoon, I have a great hurry with my Grand Cherokee, the technician in automotive mechanics cannot repair a fault:
I will be as brief:
everything started with a fault where the engine stopped complete We wanted to use and the surprise was that the car turned on the engine but presented a failure as if it were out of time and did not accelerate, the mechanic commented that it was the gasoline pump the Czech and the pressure was 50 psi, the next thing that it was checar, fuel lines, fuel pump, injectors in a laboratory were checked, distributor, position of position of position of the cranks Damaged the crankshaft sensor and the other parts are fine, it changes it and continues to do the same the engine starts normal, but when accelerating it does not run out, also presenting exploions, fire in the air inlet to the engine giving the sensation that it would be out of time for it for it the mechanic comments that it has to check where the sensor of the crankshaft goes and the information is laughed Distribute, Czech the computer proveing it in another vehicle and in a test laboratory and everything works normal, it tests with the distributor, distributor coil, changes the firing position of the crankshaft again and at the end of making a large revision to the entire system of ingenition and the fault continues to be presented again, when the vehicle is scanned Advise myself in this regard, I would like to please East, we have made several Consultas com outros técnicos e a falha não é resolvida, agradeça -me por sua atenção ...
