Hello friends I have an Optra Advance and the question is that I repair it in the 4th piston, and the mechanic told me that the 1st and 2nd piston was fine, today it was approximately 10,000 km ago that I did that repair, and my problem is that sometimes the transmission to change to 3rd hits very strong, it should be noted that this happens 1 time per week, that is practically very little, other times, I do not stop. O veículo muda de um golpe suave para o primeiro golpe ou simplesmente não muda e, quando acelerado, está em neutro, na maioria das vezes a transmissão funciona perfeitamente, essa falha é muito pequena, mas sabemos que um veículo deve funcionar perfeitamente, graças àqueles que podem me ajudar.
