intermittent jerking on Isuzu kb 260 d/c 1994
12 años 10 meses antes #23269 por cbsr1130
Hi all,
this is a great site,for manuals...
can someone help...?? when driving at a constant speed, cruising,no load on the engine, my isuzu jerks intermittently,like fuel starvation.whenever it does this i give it full acceleration to see if it is a fuel shortage but it accelerates contantly with no jerking at all.
i have fitted a new fuel pump and new filters,new ignition coil and spark plugs and plug wires, new distributor cap and rotor.
this problem only occurs when your road speed is constant and you are not accelerating.
what could it be????
kind regards
chris
12 años 10 meses antes #23585 por medialuna
Respuesta de medialuna sobre el tema intermittent jerking on Isuzu kb 260 d/c 1994
did you clean pcv valve or the egr valve something clogged in the intake system
12 años 8 meses antes #25756 por bullenario
Respuesta de bullenario sobre el tema intermittent jerking on Isuzu kb 260 d/c 1994
yeah clean all the sensors in the intake. nothing else ocurs to me.
Bernardo y 9887 otros tienen se unió al grupo Manuales de Taller de Motos 7 días
