Chevrolet Monza with varied problems
14 years 8 months before #16917 by manual-mecanica
Manual-Mecanica Response on the Re: Chevrolet Monza with various problems
In the video I see that the Mescla Eye is broken down with the temperature sensor if you can change it is cheap and it is not others to subtitle it greetings
14 years 7 months before #16967 by manual-mecanica
Thank you all for your councils,
I have solved the problem so far, but not quite, at least now it does not go out but if the revolutions are lowered when stopping at a traffic light but then they rise and stabilize. (Only only on some occasions). My conclusion is that the accelerator's piola should be chopped, which does not let the acceleration butterfly regularly regulate the tolerance of the same sensor to tolerance causing a lack of control in the maintenance of RMP.
