Cirrus problem under voltage in the coil
14 years 4 months before #19237 by manual-mecanica
Cirrus problem under the coil published by Manual-Mecanica
Hello, how are I new in this forum, I have a Mexican 99 Cirrus model, which must be changed to the crankshaft pump sensor and the complete distributor the problem was still repairing the computer that, according to the fault now if there is an output voltage to the buijias but in a very low one I would appreciate that they oriente me.
14 years 4 months before #19241 by manual-mecanica
Hala greetings if there is already power current to the coil and the correct one and the distributor had the safest thing is that the Ignition Tubobine secondary is not working well, the safest thing is that you try another coil or checks the voltage output with a test spark plug.
14 years 4 months before #19242 by manual-mecanica
Hey thank you for answering friend, look, check the coil in another car the same and if it turns on and in mine the coil output voltage towards the bijiias is not checked and it is 8.80 volts
