Peugeot 406 TD failure
14 years 4 months before #19481 by manual-mecanica
Failure in Peugeot 406 TD published by Manual-Mecanica
Good I have a Peugeot 406 STDT 1.9TD year98 which sometimes ignites the Stop pilot and electro -seasons begin to work at their highest speeds. From LIQ, refrigerant is well and of oil too. Could someone tell me what the breakdown is? Thank you a greeting
14 years 4 months before #19488 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot 406 td failure
Hello,:)
that happens because it has an electricity and the engine enters the Averia mode.
You will have to take it to the workshop to read the codes of Averia.
Have luck.:)
14 years 4 months before #19508 by manual-mecanica
Look if the temperature bulb that go on the cylinder lid when it is short is put into operation
14 years 4 months before #19544 by manual-mecanica
Hello, I have recently had a 2.1 TD with the same problem and I was cutting the skull hose that goes to the calculator, a fuse of the habitaculus was cast, I looked for the cable that gave war and solved. I hope it helps you.
All the best.
