Torque Bolt Bolts
14 years 4 months before #19596 by manual-mecanica
Torque Bolata Bolts published by Manual-Mecanica
Friends I have a consultation with a Dahiatsu crushes from 1998. I need to know follows specifications when it is the torque and the order to tighten the bolts.
Thank you very much to those who can respond or better even if someone has a manual
14 years 4 months before #19633 by manual-mecanica
Manual-Mecanica Response on the Re: Torque Bolt Torque
I guess you mean the DAIHATSU Aplausse 1589cc 16 Valves, 4 -cylinder HDE engine
1st - 2 kg
2nd - 4 kg
3rd - 6.5kg
4th loosen 90º and tighten 6.5kg screw to screw
5th Make the engine up to the total opening of the thermostat. Let cool.
6th Repeat step No. 4
7 after 1000 kms Repeat Step Nº 4
Tightening sequence:
8 6 1 3 9
10 4 2 5 7
