SELEMA RENAULTE MEGAN COUPE 1.4 16V problems
14 years 4 months before #19600 by manual-mecanica
SELELTI RENAULTE COUPE 1.4 16V PUBLISHED BY MANUAL-MECANICA
Ola I have a megane coupe 1. and I am very ranging from the rpm, I think these cars are a lot of cars when I go on the highway I do not notice anything but when I stop in the semaphors I can freak out Lake me I will see the 150rpm not to go up and go down there do not be able to do or anything you can see you can there you can there.
14 years 4 months before #19616 by manual-mecanica
Manual-Mecanica Answer on the RE: Problems SEMEULTEULTE MEGAN COUPE 1.4 16V
Good morning JJ. Your problrma is at the close of the admission collector. You go through the official service and buy the play on toric gums of the collector and butterfly box. It is not expensive, it is more the fuck to change them than anything else, already rular that are two days.
I hope you have a solution, greetings ...
14 years 4 months before #19696 by manual-mecanica
Good guy I will look at if it is to do that if I take out if I get that piece very friendly, I will tell you a greeting andx a certain beautiful cat ajjajaja
13 years 1 month before #34701 by manual-mecanica
Hello, the same happened to me and as the friend says, I changed the joints that were poorly mounted and the idle valve that I bought it in the scrapping for € 15, the joints in an € 8 spare parts store, then I only had to reset the valve disconnecting the + battery + ready. I hope it helps you.
