Corsa problem b
14 years 4 months before #20026 by manual-mecanica
CORSA B problem published by Manual-Mecanica
Hello friends, I have a problem with a corsa B this when it is hot on the check Engine and turns off and it is very difficult to turn it on after it cool
14 years 4 months before #20037 by manual-mecanica
Manual-Mecanica Response on the Re: Corsa B problem
Hello, the sensor that tells you high voltage is that there is no connection or sensor disconnected that it is already cut inside your failure it is very possible that the precion of naphtha decays since the fuel pump must have 2.9 precion bar without acceleration and acceleration 3.2 bar may be that the pump when heating declines the precion verifies its precion greetings.
14 years 4 months before #20041 by manual-mecanica
Ready I'm going to verify thanks
14 years 4 months before #20069 by manual-mecanica
Hello again when the pump the pump the pressure values ​​gave me the normal ones but another symptom was added the engine fails a lot and begins to smoke even when the smoke that comes out is black and the smell of gasoline I do not know what it can be thanks please help me
14 years 4 months before #20070 by manual-mecanica
Check again the temperature emitted by the refrigerant liquid sensor that is a cause of your problem that can be that fault or also the precion valve that is locked and a lot of precion
