Shara Picasso 2.0 HDI Exclusive 2001
14 years 3 months before #20289 by manual-mecanica
Shara Picasso 2.0 HDI Exclusive 2001 published by Manual-Mecanica
Hello colleagues I'm new here and I would like to know if you can help me. The weather has stopped working and the fuses are fine. I don't get the motorcycle maker. I don't know where to take the subject. I have downloaded the mechanical manual in the donkey but I miss more than a pigüino for the Sahara
14 years 3 months before #20310 by manual-mecanica
Manual-Mecanica Response on the Re: Shara Picasso 2.0 HDI Exclusive 2001
First you have to look if you have gas -Freon R 134
14 years 3 months before #20317 by manual-mecanica
Not long ago I charge it because I did not cool, but it is good and good to first it does not work. I have realized that the front fan before turned when the clioma was put and now not
14 years 3 months before #20318 by manual-mecanica
I do not know but it is as if the compressor did not reach the common but all the fuses are fine
14 years 3 months before #20433 by manual-mecanica
good it may be that you have some gas leaks in the circuit and you are left without gas in the circuit. all the best
