Mi Xt 225 does not turn on
14 years 1 month before #21424 by manual-mecanica
Mi XT 225 does not turn on published by Manual-Mecanica
Good
my XT 225 is a 2005 model, more than a week ago I stayed without fuel, no more, changed battery, spark plug and branch of the electrical system, all original spare parts of Yamaha, turns on, not hard until I got to my house, after arriving it did not get back. It should be noted that in the bringing to my house, it went out and the turn of the start, predia but when it stopped accelerating, go out and so again until you get home. If anyone knows that you can be failed to say? CDI, bovine, and other spare parts were tested on another motorcycle and were good ... my doubt is because the current is so discontinuous, the bovine gives continuity, the medium with multitester.
14 years 1 month before #21425 by manual-mecanica
Manual-Mecanica response on the Re: my xt 225 does not turn on
If the bovine is deficient, it is said that it is reheated therefore the current is reduced when it heats
