The Honda problem is the monitor: the car does not fail, the chek is not turned on and it is very well but suddenly when Ba Corredo goes out, as if the current would be cut, they died to me, it could be the relev He had the same problem, and when he goes out, he no longer stops to turn on and if the chek is turned on and the suich was a little while and he turned it on and already turns on well and the chek is turned off but when he goes out, he turns off, he turns out, giving the little time the little time as about 5 minutes Buelbe Learn and without failure
