Problem with a Corsa !!!
14 years 1 month before #21497 by manual-mecanica
Problem with a Corsa !!! Posted by manual-mecanica
Hello friends, I want to consult about a problem that I have with my Corsa, to start, it is a Corsa 2008 1.6 City 8v.mpfi. The problem I have is that it stops in relief or walking, scanning with two different computers and does not give any fault, you are changed censor (captor) of speed, step by step, spark plug It should be clear that everything that is changed is original according to GM specifications. Today testing in my house, I found that I touch a black wire that leaves the central tray of the injectors and the car that was regulating well suddenly stopped, this cable is black I followed it and leaves the bunch of cables that comes from the Ecu It automatically stops, this cable inside the tray has a slightly hard section I was playing it but did not make the fault again. It may be that this cable is giving the fault I have.
If someone can guide me, I would appreciate them, see you later.
