ABS AND SERVICE 4WD
14 years 1 month before #21583 by manual-mecanica
ABS and Service 4WD published by Manual-Mecanica
I have a problem with a 1500 2001 model Silverado. For a few days I eat the ABS when brake and on the warning of the Brake, along with this in the message box on Service 4WD. I need to support me to solve these two problems.
14 years 1 month before #21603 by manual-mecanica
Manual-Mecanica Answer on the Re: ABS and Service 4WD
First of all, you check what amount of pills and shoes you have and the brake fluid level, if everything goes well checks the mass cables, it is described or sulfate that goes from the battery to the body of the car.
