1.9 TDI Pole Distribution
14 years 1 month before #21595 by manual-mecanica
1.9 TDI Pole Distribution Published by Manual-Mecanica
I would need to get the Volkswagen Polo 1.9 TDI of 100 hp of the year 2006 to solve problems when changing the distribution strap.
14 years 1 month before #21596 by manual-mecanica
Manual-Mecanica Response on the Re: Distribution Pole 1.9 TDI
What kind of engine do you have and what are your problems to see if we can give you a hand
14 years 1 month before #21598 by manual-mecanica
I would like to know the draft of the distribution to replace the strap and how to tighten it coordically
14 years 1 month before #21601 by manual-mecanica
Here you can download the manual in this forum and for the tension of the belt the tension bearing already comes with its signaling to graduate the tension I repeat first of all see what type of motor is since between one model and another change the types of engines.-
