Zuzuki Ambar Code Shield Year 95
14 years 1 month before #22083 by manual-mecanica
Zuzuki Drive Code Year 95 Published by Manual-Mecanica
Greetings to all, please if someone could help me !!
I require the fault codes to manually scan a zuzuki shield year 95, motor model: H20A, 2000cc
thanks
Remember: Today for my morning Porti ....
14 years 1 month before #22165 by manual-mecanica
Manual-Mecanica Response on the Re: Zuzuki Averia Code Shield Year 95
Look if this serves you,
Miguel
Suzuki Vehicles 1986-1995 obd1 code search
to obtain the motor codes of the check of Suzuki vehicles is quite easy. All you need is to access the fuse panel under the driver's side. In the lower left corner of the fuse box, there is a fuse or the diagnostic connector that you have to install a fuse. Once this is done and after turning the key on the instrument board, the codes begins to blink.
To erase the codes, turn the key and remove the fuse. Then disconnect the negative battery terminal for 30 seconds and re -connect. (In some models, the duration of the disconnection is up to 60 seconds, see the manual or contact ATS).
To read the codes that followed without interruption, use it as a guide: Code 13 is a long flash followed by 3 short flashes. Each code is repeated three times before going to the next code after a pause.
These are some of the Suzuki popular codes for 1986 to 1995 vehicles:
Code 12 of the Normal System
Code 13 Oxygen sensor failure
Code 14 The temperature of the circuit circuit cooling by failure, high voltage
code 15 engine engine of the circuit refrigerant per failure, low voltage
code 21 of the accelerator position sensor (TPS) of fault circuit, high voltage circuit, high voltage
code 22 Failure circuit TPS (TPS), Low voltage
Code 23 Failure circuit air temperature sensor,
high voltage
code 24
The vehicle speed Failure circuit sensor Code
25 High voltage
Code 34 Air mass Failure circuit sensor,
Low
voltage
Code 41
Falling
signal
Code
42 54 Fifth Arts of the Circuit Switch By Failure Code 71 Switch circuit test
If you have any Suzuki OBD1 Codes that wanted to fix, please visit this site:
solution of secret automotive problems
