dense white huo when reaching normal temperature of
14 years 3 weeks before #22366 by manual-mecanica
It may be a problem of the button packaging since if the creat the same compression relationship is higher, which can be outraged that the packaging does not resist that compression in such a way that when the engine heats at normal temperature the piston absorbs oil from the lubrication galleries by the damaged packaging
14 years 3 weeks before #22418 by manual-mecanica
I do think it is on the part of the rings and have to disarm and it is better to check that thoroughly so hands to work
14 years 2 weeks before #22578 by manual-mecanica
hello friends. I tell you, take out the cylinder head to perform hydraulic and chemical tests to revive the guides of valves that had changed. Meanwhile disarmament guns, rings. Oil scrapers attached to the four pistons, I fell. I already bruñi and install the rings I am inpeque yesterday delivers the car at last sleep quiet from now on it hit completely hahaha thanks to all for your goodbye answers.
14 years 2 weeks before #22718 by manual-mecanica
Problem!! Valve shells enter the oil through there is the white smoke because it burns oil ((or did not plan the joint and water and water joint at the same time)) but if it does not consume water it can be the caps, ok, "lamauto.com"
14 years 4 days before #23027 by manual-mecanica
Hello, if you tied you, you noticed that the oil rings that stop as a spiral was not spliced, and you also checked that the head torque is correct
