- Thanks received: 1
06-19-2025 Hits: 625 Technology
Totoracing2 wrote: Good evening I need help with a Dahiatsu terios, the problem that presents me is that when reaching a service temperature the truck makes a kind of explosion for the admission and escape at the same time, as if the current was cut and returned, the light of Chek Engine turns on and turns off at the time that the fault occurs I have reviewed coils Buying the positive of the direct coils of the battery the direct land to chassss and the signal from the game in the ECU is removed the fault .... in the diagnostic team the code P 0350 generates me (Failure Main Ignition System) I hope that someone will occur this problem and help me with an answer to this fault that has taken me more than a month thank you very much ....
