Mazda F2 engine
13 years 11 months before #23453 by manual-mecanica
Mazda F2 Motor published by Manual-Mecanica
I need help with the engine timpo synchronization, if anyone knows : SIDE:
13 years 11 months before #23456 by manual-mecanica
Manual-Mecanica Answer on the Re: Mazda F2 Motor
Specify a bit what you want. Because if you want to synchronize the shield of the cams with the crankshaft there are several manuals here that tell you. If you don't find it, let me know ..
13 years 11 months before #23457 by manual-mecanica
Gear synchronization cams with rotor gear
13 years 11 months before #23460 by manual-mecanica
I have done it in Yale forklift engines, displacement 2200 cm3, you put the camshaft pinion with the camshaft guide The crankshaft with the distribution pine Confirm the synchronization points again, let it be in the same place, if not, re -release and align again, I hope it serves you from Colombia Bogota
