I can't find the connector to scan
13 years 11 months before #24119 by manual-mecanica
Do not meet the scan connector published by Manual-Mecanica
It would be very grateful if someone would measure where the connector of a civic mod 95 is located
13 years 11 months before #24148 by manual-mecanica
Manual-Mecanica response on the Re: I do not find the connector to scan
Greetings, the OBD connector is located by the pedals under the board's side. Find it there, luck.
13 years 10 months before #24462 by manual-mecanica
Hello on the left side you have a retire it purse and there are lo tnes greetings
13 years 9 months before #25999 by manual-mecanica
Find it under the glove compartment, it is a blue connector, there are 2 and 3 pins
13 years 9 months before - 13 years 9 months before #26002 by manual-mecanica
Apparently there is a problem to be able to locate you, the American version models are the ones that bring it to the right side under the glove compartment you have to put your hand behind and they are blue female connectors, it is 1 or 2 of 2 and 3 lines and if they have not touched it much it has a green capuchon if it is not an American version look for it elsewhere.
Last edition: 13 years 9 months before by . Reason: Add attached file
