I have injection problems Stratus 2.4 Turvo
13 years 10 months before - 13 years 10 months before #25206 by manual-mecanica
I have injection problems Stratus 2.4 Turvo published by Manual-Mecanica
Good afternoon partners, someone could help me with this turvus turvo 2.4 I do not have pulsation in injectors at the beginning only function the ijector 1 and 3 after Checar computer and censors no longer worked the 4 injectors I am not sure if it is the original alarm module I do not find it, suggest the censorsor of crankshaft I am already desperate, Grasias.:(
Latest edition: 13 years 10 months before by .
13 years 9 months before #25524 by manual-mecanica
Try first if there is continuity in the connectors of the injectors and since you have the ease of a computer sees if it throws any codes otherwise the injectors may be covered if you have not maintained them, you send them to clean with ultrasound you buy their filters the toric joints and mount them to see how it works.
13 years 9 months before #25593 by manual-mecanica
That such a Moff1 already works the car The problem was the CKP that handles pulsation in injectors and food to the greasy ignition coil by your advice greetings. ;)
13 years 9 months before #25997 by manual-mecanica
The problem can be your crankshaft sensor, not long ago I had a similar problem with a voyager, I sent me 2 or 3 pulses to the injectors nothing more, I thought it was the alarm or the computer, and I finish that sensor being that sensor
