I ask for help, I have a Malibu 3.1l V6 2002 12v
13 years 9 months before #25559 by manual-mecanica
I have a Malibu Chevrolet, a water hose was burst, I already repair it, but I turned on a red icon on the board, it is the image of a radiator with a low level of antifreeze ...
already filling water, but it is not removed, how it is removed .. ???
13 years 9 months before #25713 by manual-mecanica
Czech if you bring sensor the kidney kidney tel this time this crossed or if it does not disconnect the battery may serve you and if you do not see Autozone if there are in your country there they delete it with the scanner lucky friend.
13 years 9 months before - 13 years 9 months before #25994 by manual-mecanica
The sensor takes it in the recovery deposit, the solution would be to replace the deposit, but it is somewhat expensive, approx $ 1500 Mexicans, try to disconnect the sensor, it is the only connector that is in the deposit, if it disappears, you can leave it like this, or try to bridge the connector, they are the economic solutions that I recommend you
Last edition: 13 years 9 months before by . Reason: sensor location confusion
