Hello everyone, I have a 1994 Full Injection Model Vocho, and it has a problem, when I start it in the mornings, the matter is that once the engine is heated (I want to load gasoline for example) it takes to start as if you drown, what can someone be helped me ???, do you have to change a sensor?
Hello, you will see if the theme of not starting only occurs hot is devoid to the ignition pill. Disassemble the distributor inside it is lodged and fine greetings
