Meters
13 years 8 months before #27271 by manual-mecanica
Metters published by Manual-Mecanica
I am from El Salvador and I know a couple my car began to give a problem that none of the markers responds neither gasoline nitemperatura nor tacomethre nor velocimetro quicira know if anyone has run into that problem the car is a mitsubishi lancer 2000 with 4G92 motor agency 1600 cc. I already burst the instrument fuses and this one is 10 amps
13 years 8 months before #27380 by manual-mecanica
Manual-Mecanica Response on the Re: METERS
Hello my question is whether reviewed if Tellega tension to the picture and mass
13 years 8 months before #27381 by manual-mecanica
but Tellega tension reviews the connections of the cable mallets
13 years 7 months before #27819 by manual-mecanica
If you arrive and the lands are well only works normal the mornings later no Buelbe to work all day
13 years 7 months before #27930 by manual-mecanica
Well, the instrument board was reviewed and I manage to work by having the food of 12 volocimetro in the velocimetter because it is totally electronic has no cables and it works only that although the hateful and temperature turn the car and the temperature the parking brake pilot is lit not as before only the fuel that marked marking. If any colleague can throw a little hand in this fault, I would appreciate them very much
