Problems with Ford Ranger Motor 140 1990
13 years 5 months before #30336 by manual-mecanica
Problems with Ford Ranger Motor 140 1990 Published by Manual-Mecanica
The fault occurs when it circulates when it puts 2nd fails this is pulling when the third is put in this is to fail more; in the first it does not fail only when putting 2nd.
13 years 5 months before #30917 by manual-mecanica
Manual-Mecanica Response on the Re: problem with Ford Ranger Motor 140 1990
Before having this fault that were repaired or stated that the fault originated I have a ranger 94 I had a similar one my fault was the clutch you can check in a sensilla way, put it in motion fourth and you take out the clutch must be automatically turned off if it is thrown it is to fail luck :)
