Good evening if you mean the radiator the radiator on the side will carry a thermocontact with two cables disconnect them and bridge them with a cable and the electro -ventilator will work continuously
The k tells you dirty hands is incorrect, pke If you bridge the sensor outputs you are going to the computer, aki is done is to disconnect the sensor harnes and automatically in 10 Ò 15 seconds the computer sends the order to the relay of the motorcyclers and light at the moment, as long as it is not engine 3.4, pke if you disconnect the sensor the sensor Programming from the radio, the best waters change the ... CTS refrigerant sensor.
