Mitsubishi L200 problem
13 years 4 months before #31726 by manual-mecanica
Mitsubishi L200 problem posted by Manual-Mecanica
Hello everyone I have a problem with a L200 diesel, everything is fine, the problem is that in the height at +- 4000 meters above sea
13 years 4 months before #31728 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Mitsubishi L200
Hello good night, look at your problem is in the Boos Due sensor or atmospheric pressure sensor what you have to do is to disconnect it when you are at height and will start the engine right away, well I wish this data serves you a lucky friend
13 years 4 months before #31729 by manual-mecanica
good night and where is located
13 years 4 months before #31730 by manual-mecanica
It is located behind the intercooler is a sensor that has three electric cables and on one side a hose is released towards the admission multiple
13 years 4 months before #31731 by manual-mecanica
The other that sensor I do not mean that this bad if it is a problem that all the mitsubishi have a higher.
