Astra 2002 Radiator on solved
13 years 1 month before #34732 by manual-mecanica
Astra 2002 Lighting Radiator Published by Manual-Mecanica
This is the fault
when putting on the fans are lit and they make excess noise and do not go out until the key is taken out.
Change the temperature sensor and followed the same ...
Solution
The radiator carries a bulb that measures the pressure of the AC, it meets on the side of the radiator, seeing it in front of it in your left hand, it is very likely that this is the fault.
In my case I only cleaned it and installed it again and the fans stopped lighting in cold. Now it rises to 90c and normally lights.
I hope it helps you ...
13 years 4 weeks before #34988 by manual-mecanica
Manual-Mecanica Response on the Retra 2002
: UNSURE: Thanks for the fact, maybe one day I need ...
