Water consumption in Lupo 2005, does not pass to oil
13 years 4 weeks before #35018 by manual-mecanica
:( Mi Lupo 2005 1.6 is consuming antifreeze, they already checked hoses, leaks, etc. And they found nothing, until the bopmba of water, I have checked the oil and does not have water or look like "chocolate milk", already 1 month ago that consumes me. What can be ???
13 years 4 weeks before #35021 by manual-mecanica
I have a question, don't heat your ship
13 years 3 weeks before #35127 by manual-mecanica
For me they could be several reasons.
1- that is losing for the heating radiator
2- that is evaporating through the combustion cameras.
The second is a frequent problem, since when the butt packing is damaged, water usually passes into the combustion camera, and it evaporates by reaction of fuel ignition.
Good luck with your problem
13 years 3 weeks before #35148 by manual-mecanica
Thank you very much for the answers, they will help me. And is the repair of the second option you gave me? Greetings!!!
13 years 3 weeks before #35149 by manual-mecanica
Greetings.
1.-Coince with Felipe, check the heating radiator, you can detect it looking for moisture on the floor carpet of the front seats.
2.-Revise something as simple as the tank and the recovery cap, it is common to have small leaks on the cap.
3.-Special attention to the connectors of the hoses, especially those that are screwed to the block and/or the head, are plastic and get to have small leaks due to fissure.
I hope this information serves you.
