Automatic box oil
13 years 3 days before #35759 by manual-mecanica
Automatic box oil published by Manual-Mecanica
Good, I need to know what kind of oil carries the automatic gearbox of my Accord Model 95. They tell me that it can take ATF Dexron III or ATF +4.
Can you help me?
13 years 3 days before #35760 by manual-mecanica
Manual-Mecanica Response on the Re: Automatic Box Oil
This model uses Dexron III.
Use approximately 2.4 liters.
Luck
13 years 2 days before #35790 by manual-mecanica
This model carries dexron II or III The quantity of oil is depends on the amount that will take you away if it is compliced ​​empty can take about 8 liters if the torsion converter is empty otherwise you have to fill out
