Who broke Ford Triton spark plug?
13 years 2 days before #35797 by manual-mecanica
Who broke Ford Triton spark plug? Posted by manual-mecanica
Who has broken a spark plug of the Ford F 150 engine 5400, we can withdraw without lowering butts. This is a bad common
13 years 2 days before #35805 by manual-mecanica
Manual-Mecanica response on the Re: Who broke Ford Triton spark plug?
Not really all the time passes but it is not difficult with the same spark plug but exagonal you take it out if it is very tight, place brake league or marine formula it penetrates the thread and loosen the spark plug if in case it does not come out with these mechanism, buy a male and this one takes it out if you need to lower the camera unless the thread is damaged
13 years 1 day before #35822 by manual-mecanica
The problem lies in the fact that these spark plugs are for 100mil km, and they are removed and broken with everything but this truck is not coming out is 2004
13 years 1 day before #35825 by manual-mecanica
There is a piece I do not remember the name but it is equal to a male but this piece is square if it takes it out for you has to put it then you give it a dry blow then with a dice you toured it and it comes out
