Error codes in Volswagen Gol
12 years 10 months before #37148 by manual-mecanica
Manual-Mecanica Answer on the subject Error codes in Volswagen Gol
Basically what the Scaner tells you is that you have a problem in the shade Lambda, which is not known why it delivers low signal, what does not close me is that it says shaded Lambda 2 that is, does your car have a second shade Lambda ds after the catalyst?
12 years 9 months before #37297 by manual-mecanica
It is a Station Power 1.6 of 2011 Brazilian goal
12 years 9 months before #37298 by manual-mecanica
If you have catalyst
12 years 10 months before #37302 by manual-mecanica
Generally the 2 Lamda sometimes accuses failure in the Catalitical ... or the probe can be bad
check it well.
