Chevrolet Lacetti crossroads
12 years 10 months before #37184 by manual-mecanica
Chevrolet Lacetti crossroads published by Manual-Mecanica
Hello I have a lacetti of 2008 that do not light the lights of Cruze or the long ones, the long ones if they light when they do raffles, and the positions of position and the antinieblas normally light, the failure will come from the switch of the lights, or it has some interspersed device before reaching the current to the headlights
12 years 8 months before #38322 by manual-mecanica
Manual-Mecanica Response on the topic Chevrolet Lacetti crossing
Goodssss, I have that same problem and in an official concessionaire of the brand they told me that it was a cable that had to modify the box, but what cable is it? And how do you have to modify it? Can anyone give me help? Greetings and thanks
12 years 8 months before #38323 by manual-mecanica
Disassemble the instrument frame, just behind the picture, there is a kind of connector, remove it from your accommodation (it becomes a little bad, but take it from where it is lodged), and you will realize that a part is required, cut the cables that are required, peel the tips and splicing them, you will see how the crossroads look.
Greetings.
9 years 3 months before #50861 by manual-mecanica
Good afternoon, I have that same problem I will check the connector anyway someone can pass the electrical circuit scheme, thank you very much
