Toyota Hiace initial ignition failure
12 years 10 months before #37224 by manual-mecanica
Initial ignition failure of Toyota Hiace published by Manual-Mecanica
Hello, I have a Toyota Hiace problem with a 1RZ engine when I want to turn on my car does not turn on unless it feeds it with gasoline then is normal. I already changed temperature snsor, and the gasoline pump. Refresh the check and it does not show failure so much so I do not solve the problem
