Peugeot 306 Electric Failure
12 years 10 months before #37242 by manual-mecanica
PEUGEOT 306 ELECTRIC FAILURE PUBLISHED BY MANUAL-MECANICA
Hi, I have an XN 306 98 Peuxot, but it does not start, it does not pass curling to the spark plugs, I buy the coil, but it does not start, what can I do? Help for favos
12 years 10 months before #37287 by manual-mecanica
Manual-Mecanica Response Peugeot 306 Electric Failure Theme
Try to look for more, set the medium spark plugs to the continuity of the cables and set the cables that go to the coil there I gave you a couple more things so that you look ...
12 years 10 months before #37290 by manual-mecanica
did you notice that the sensor by inertia is not activated?
12 years 10 months before #37291 by manual-mecanica
Do you refer to the inertia sensor to the sensor that cuts the current that goes to the gasoline pump, in case of overturn or clash? What sensor do you mean?
12 years 10 months before #37299 by manual-mecanica
Exactly, because the very ingenious Peugeot range put it on the shock absorber then any blow is activated and you will not be able to start the car until it disables it
