Failure LEFT POSITION LIGHTS
12 years 10 months before #37278 by manual-mecanica
Failure LEFT POSITION LIGHTS PUBLISHED BY MANUAL-MECANICA
Good colleagues, I have a problem in a Hyundai Accent of 95, the position lights fail both that of Alante and the back of the left side, to see if you can help me, that I have to pass itv and we are bad of pasta, hehehe, thanks.
12 years 10 months before #37282 by manual-mecanica
Manual-Mecanica response on the subject Issue Lights LEFT SIDE
As a general rule if you fail the position of the same side of the car and they are not the bulbs, the problem is a molten fuse. If you know how to look if you are well you look at it and if you do not limit the manual of the car that tells you what it is and you change it.
12 years 10 months before #37283 by manual-mecanica
ok, but the fuses of the lights are in the box that is next to the engine?
12 years 10 months before #37284 by manual-mecanica
Cars can have more than one fuse box. Normally one in the engine and another inside, so he told you to consult the owner manual if you have it.
12 years 10 months before #37285 by manual-mecanica
Ok, the workshop manualm lowered, ok I get the owner and Buasco, thank you very much for your socio -help.
