Hi, I have a Ford Ka 1.3 with the MAF connected tab does not regulate and do not make the injection, when it is regulated low and accelerates not perfect but quite well. What can be, then they changed the cylinder lid joint began to do that
12 years 9 months before - 12 years 9 months before#37361by manual-mecanica
Manual-Mecanica response on the subject Ford Ka 1.3
Hello, the MAF sensor is fundamental in this vehicle since it calculates the fuel that must be injected to know its proper functioning you can measure with a tester in one of the cables that must be in 1.45 V in idle at 4.80 V in acceleration or if not with a scanner you can see its operation but I think that all your problem is the sensor greetings
