Kangoo 1.6 8v does not start
12 years 9 months before #37558 by manual-mecanica
Kangoo 1.6 8v does not start published by Manual-Mecanica
Kangoo 1999 1.6 8v Motor Tour does not start I have no pulse injection I have no spark in coil, when I turn if I have a positive fuel pump in positive coil in computer injerents tested in bank it is fine, computer engine wiring to a steel sensor well, from computer to coil well, from computer to injectors well can someone give me a hand? THANK YOU
12 years 9 months before #37563 by manual-mecanica
Manual-Mecanica Response on the Kangoo 1.6 8v subject does not start
Riguenal and/or Lady Tree Sensors Lucky
12 years 9 months before - 12 years 9 months before #37584 by manual-mecanica
Yes, sir .. almost certainly is the motor steering sensor. If this sensor is burned, or the cable is cut, it does not start or by chance. In the Kangoo K7M, it is installed in the box of the box. It has the shape of a butterfly.
I send you an attachment with the image of the piece and the location in the vehicle.
Latest edition: 12 years 9 months before by .
12 years 9 months before #37614 by manual-mecanica
Thank you guys for the aid I already resolved it calmly and although everything was good the computer pins were a little and caused that the terminals on the computer did not make good contact and they were those of the steering wheel ssor, thank you by By Gaby
12 years 9 months before #37615 by manual-mecanica
Gordillen very good your help but when I saw it it was already late I had already solved it was not the steering wheel ssor were the ssor pins on the computer that made false contact but the problem was that was there the same thank you very much and if any you see I can help you in something, let me know again thanks by by gaby
