Unstable idle Volkswagen Gol 96
12 years 9 months before #37776 by manual-mecanica
Manual-Mecanica response on the unstable idle the topic Volkswagen Gol 96
You can only get code if the check's light remains on, it has the power loss the engine
anyway I leave you a liks so that you see if you find how to get codes of manual
fprma is
12 years 9 months before #37784 by manual-mecanica
What are you using? Find a launch x431.
As for the failure, it is usually the IAC or the TPS. IAC = minimum step -step motor and the TPS = Butterfly position sensor. But Eye is not just changing them, it is a matter of verifying voltages and checking sensors and lasts the computer.
On the other hand it can be air entrance, apply water above the multiple of admission if it feels that being on the car tries to turn off is an air inlet.
12 years 9 months before #37786 by manual-mecanica
Verify that there is no additional air income, if that occurs the reling valve produces that variation, it also verifies the synchronization points in the distribution band just in case a tooth has not been skipped, also check the ignition time .... comment how it went ...
12 years 9 months before #37819 by manual-mecanica
Hi, Mayck, I had the same car and with exactly the same problem.
The first thing I checked was the motor step by step, and it was not that.
Then, I went for the injector: we checked, we clean, measure; It wasn't that.
Finally, the problem was in the potentiometer (position sensor) of the butterfly box.
For the same wear, he begins to send erroneous information to the calculator, and begins to badly moderate the engine.
I hope this info serves you. Luck!
12 years 8 months before #38002 by manual-mecanica
Look at there is no air admission hose that is broken or loose since that causes instability in that lucky vehicle
