Eclipse GST 98 - Normal sensors
12 years 9 months before #37764 by manual-mecanica
Eclipse GST 98 - Normal sensors published by Manual -Mecanica
Good morning, I have a mitsubishi eclipse GST Model 98.
Recently I bought a scanner to read the values ​​of the ECU, the device works well, but I would need to know what are the correct values ​​that this car should have in each sensor to be able to compare them with the information that the scanner gives me.
Greetings and thank you all for help.
12 years 9 months before #37778 by manual-mecanica
Manual -Mecanica response on the eclipse GST 98 - Normal sensor values
- The t ° sensor varies according to the engine temperature
- The TPS sensor must be varial between 0.5 and 1.1V with the butterfly closed, until it reaches a value of 4.8 V Apx. With the butterfly open, this is proven with different acceleration states.
- The oxygen sensor must vary constantly in ranges of 0.350 to 0.750V.
- The MAF must vary 1.8v to 2.9va I slowed down and accelerating should vary.
Here is an explanatory video .. luck.
12 years 9 months before #37788 by manual-mecanica
Thank you very much for the help Guillermo!
I make one more query:
my car had an error in the TPS sensor, clean the log error and so far it did not give it again, what I do not know is whether after the error the computer automatically resets the correct values ​​or if you have to change them by hand. Now there are no mistakes but it seems to me that this gasoline past because after a 1600 km trip there was Ollin on the bumper, which obviously left the escape.
Greetings and thanks again for the aid
12 years 9 months before #37790 by manual-mecanica
What error did you have? What code .. ???
If you used the Scaner, you should give you a breakdown code, from there you must leave ...
you comment and there you can be and how it can be solved.
greetings
12 years 9 months before #37812 by manual-mecanica
The error was: P0120, according to the description I found on the following page: www.troublecodes.net/mitsu/ means: Throttle Position Circuit. The issue is that until now it did not appear again and I do not know if the issue of excess fuel consumption that I told you in the other message, it can come from that error or it is for something else.
