Diesel engine
12 years 9 months before #37782 by manual-mecanica
Diesel engine posted by manual-mecanica
I need to know why a diesel engine expels a lot of white smoke and has no power
12 years 9 months before #37783 by manual-mecanica
Manual-Mecanica response on the diesel motor
Most likely, the water is being passed to the combustion camera. bone inside the cylinders. Most likely, the packaging which is damaged and you have to change it.
In most of the case, it shows in the engine oil or in the refrigerant liquid (radiadior water), check the oil and water you want this one of the 2 ...
Bye lucky I hope it serves you ..
12 years 9 months before #37792 by manual-mecanica
It is clearly a water filtration to some cylinder.
As Luchito2010 says it may be the cylinder head packing.
Check the water status, check the level and if it bubbles or blows. You will have a more occasional diagnosis.
Luck.
