Problem with a S10 97 Version American truck
12 years 9 months before #37813 by manual-mecanica
Problem with a S10 97 Version American Version published by Manual-Mecanica
Good friends, I tell you that I have a problem with an S10 first came with the damaged catalyst we changed it and all good now gives me the error P0141 but the problem itself is that it turns on well, it moves well but after a while it begins to give problems as if a cylinder were giving problems begins to lose strength already changed gasoline pump, spark plugs, gasoline filter, the injectors were tested. coil and the same believe that this error P0141 can give me that fault
12 years 9 months before - 12 years 9 months before #37816 by manual-mecanica
Manual-Mecanica Response on the problem with a S10 97 Version American truck
That code in Obdii means.
- HEATED OXYGEN SENSOR (Sensor 2 Block 1) - Defective circuit.
Which means you have a problem with oxygen sensor wiring or internally you have a problem with it.
You must prove your correct operation.
Technical description
Heater of the O2 sensor of the circuit malfunction (Bank 1, sensor 2)
What does that mean?
This code means that the oxygen sensor heating circuit in Bank 1 decreases the time needed to enter closed loop. As the O2 heater reaches the operating temperature, the oxygen sensor responds by switching according to the oxygen content of the exhaust gases that surrounds it. The ECM tracks the time it takes so that the oxygen sensor to start switching. The ECM (based on the coolant temperature) is determined that too much elapsed before the oxygen sensor began to work properly, P0141 will be created.
Symptoms
It is likely that you notice a bad fuel economy of check light of the check.
Causes
A P0141 Code can mean that one or more of the following has occurred:
* Open or short to mass in the wiring
* O2 heater High -resistance wiring circuit
* O2 heater of O2 Resistance Element Element is high
* short internal or open in the heating element.
Hopefully the info serves you.
And checks the spark plug cables should give resistance about 8 khoms per meter.
Luck
Latest edition: 12 years 9 months before by .
12 years 8 months before #37893 by manual-mecanica
THANK YOU, TUBE TO CHANGE THE TWO OXYGEN SENSORS AND PROBLEM RECOVED THANKS
