My lights flash
12 years 8 months before #38145 by manual-mecanica
My lights flashed by Manual-Mecanica
Well there is a 760 gle volvo of the year 90 the problem is that there was a blink of the dashboard lights and now it does not start and the battery is dead someone can tell me what is the problem of the car
12 years 8 months before #38284 by manual-mecanica
Manual-Mecanica response on the subject my lights flash
First I think you should load the battery and see if it has a burned fuse and if so, because possible short circuit or the alternator already needs a change of coals or the regulatory box is failing I hope to know that you found bad luck
12 years 8 months before #38285 by manual-mecanica
Hello, look at the alternator load, surely I shouldn't charge well a 14 V voltage a greeting
12 years 8 months before #38293 by manual-mecanica
For me you have to control the regulator but I play that they are the diodes that I already burn you a fuse and I do not know if the battery does not break you, it usually happens that when the boil is loaded and evaporates the roast
12 years 8 months before #38339 by manual-mecanica
Well thanks to all for your contribution I review it and I saw that the regulator's charms are worn that was all thanks.
