ELECTROVENTILADOR DIESEL 1.9 Model 2009
12 years 8 months before #38211 by manual-mecanica
Manual-Mecanica Response on the Electrovantile Partner Diesel 1.9 Model 2009
Hello if you disconnect the sensor and the ELCTRO turns on when the engine is running that I design that the system is well fixed :: the circulation of water that is good touches the two water hoses the one below and the one above that they have the same temperature that assures you the circulation of water and that it open the thermostat .. And if when you disconnect the sensor the sensor low the temperature !! If there is no water circulation by x cause it can be the sensor does not have the appropriate temperature and do not turn on .. if you have everything well sure is the sensor .. Podes Provar with a heat gun by taking it out and covering the hole with something .. and the heaters have to turn on the electros ... and if not the sensor does not go ..
12 years 8 months before #38212 by manual-mecanica
12 years 8 months before #38265 by manual-mecanica
Copa68 What do you mean with a clema in poor condition?
Electromecanicatila If I disconnect the 4 -contact blue sensor with the engine running the 2 electro -seasons light at first speed and immediately pass at maximum speed. This sensor already changed it but the fault persists. The upper hose feels hot and the whole radiator too, do not verify the lower maguera.
Does anyone have the electrical diagram of connections?
12 years 8 months before #38272 by manual-mecanica
But check if your thermostat works well?
Check it
12 years 8 months before #38273 by manual-mecanica
The thermostat already changes it but the problem follows.
