Clutch pedal
12 years 8 months before #38242 by manual-mecanica
Clutch pedal posted by Manual-Mecanica
I have a S10 99 4cil, with the very hard clutch pedal short short but this hard demo I am able to buy it there is a way that this more suabs or so is thanks for your answers
12 years 8 months before #38246 by manual-mecanica
Manual-Mecanica Answer on the clutch pedal
Friend if your pedal is with piola, I recommend you review it.
Sometimes the piolas for the time are grouped and the pedal becomes hard.
What I recommend that you review it and lubriquques with some lubricating liquid.
If you could not lubricate it, you just have to change it.
Luck
12 years 8 months before #38248 by manual-mecanica
In this case it is idraulic that could do
12 years 8 months before #38249 by manual-mecanica
Check if the system is purged.
It can be air in the system.
12 years 8 months before #38252 by manual-mecanica
The purgation is off or on the engine and the purge is that the pedal is precise or pump up and purge thanks : UNSURE:
