Coil de Inition, 2 and 3 connectors
12 years 8 months before #38289 by manual-mecanica
Coil de Inition, 2 and 3 connectors published by Manual-Mecanica
Greetings, a couple of days ago I changed the engine in my Suzuki Sidekick 1997, I put a 2002 Suzuki engine, which differs from the previous one in the connection of the coil, in the new engine the coil are three hooks and in the previous one of 2 hooks, I need to know if I can use the new engine with the coil of 3 hooks even using my old ramar and without changing the vehicle of the vehicle.
Since an electric told me to change the computer and module to use those coils or continue with my 2 hooks coil and another tells me that I just have to eliminate a line and thus use the coil of three hooks .......
who can help me with this little situation ....
12 years 8 months before #38294 by manual-mecanica
Manual-Mecanica response on the Coil de Inition theme, 2 and 3 connectors
If it is for a cylinder coil, the 3 pins go like this, 2-negative and 3 pulse of 5 volts to energize the transistor that is inside the coil-the 2pines is 1 ignition and 2 primary exit looking for the transistor either in the ECU or in an ignitor module where I would receive the 5 pulsed volts that I put to the 3 pins. any connection, suggested to consult each one's diagram and there would be your own analysis
