problem at Passat 96 TDI Motor 1z
12 years 8 months before #38290 by manual-mecanica
problem at Passat 96 TDI Motor 1Z Published by Manual-Mecanica
Hello, to see if someone can help me I have a problem with my passat I flash the oil precion light and the 2000 laps and the alarm sounds and I medium the precion and it has a good precion I change the vulbo and it remains the same connects the scanner and a failure appears in the lodging needle of the injector medi the injector and the harmony will be well. or some help thanks
12 years 8 months before #38291 by manual-mecanica
Manual-Mecanica Answer on the problem subject to Passat 96 TDI Motor 1Z
Tell me the sccaner error number
12 years 8 months before #38292 by manual-mecanica
Hello, I do not remember the code said permanent defect lodging captor injector needle
