Help with an arrangement
12 years 8 months before #38504 by manual-mecanica
Help with an arrangement published by Manual-Mecanica
After an apparatus areeglo (the chain tensioner was broken and the entire distribution kit broke down the housing the escape valves already arranged and changed several pieces) I turn on my pick -up truck Nissan D21 it despair and the mechanics do not help him
12 years 8 months before #38511 by manual-mecanica
Manual-Mecanica Response on the subject helps with an arrangement
See if it is spark or fuel what you lack to start so we gia where you have to check
12 years 7 months before #38545 by manual-mecanica
Manual-Mecanica Answer on the subject helps with a Pick-Up D21 Nissan arrangement
If there is a fuel spark and everything ..
new details in the morning light normal (I put new spark plugs) the run the time that is 5 minutes 30 minutes one hour, but after turning it off it the in6Tentum turns back again and does not start at all that once I saw what they did, take away the connections of the injectors and try to start and start shortly after connecting the injector 1 and 3 The next bell connected the injector 2 and 4, stabilizy I took it to take a role and worked perfectly, I turned off the descend for a while and did not want to turn on again tried the above again but it no longer worked only caused that the battery will go down the attempts ....... I don't know what I can do more
12 years 7 months before #38559 by manual-mecanica
If you change the excape and admission valves and give start problems do this
1- Check the caliber of the valves D21 is 8 admission and 10 excape
2- Review the engine compression with a meter
greetings from Costa Rica
