Problem with Nissan Murano
12 years 7 months before #38618 by manual-mecanica
Problem with Nissan Murano published by Manual-Mecanica
I have a problem with the Nissan Murano 2005 when it is in minimal begins to tremble and it seems to go out we review fuel pump, flow sensor, coils and nothing that can be?
12 years 7 months before #38628 by manual-mecanica
Manual-Mecanica response on the problem with Nissan Murano
Hi, I am Alfonso and look for your problem
1) There is no set forth or failure code,
2) Wash the engine acceleration body.
3) Monitor the cicqueñal position
or change them, and see if oxygen sensors and air flow sensors work. Those are the points to be corrected ok luck and you tell me what happened ok.
12 years 7 months before #38633 by manual-mecanica
Thank you very much for the contribution, we review everything but the problem turned
