Hello everyone, I have a problem with this car is from the year 2002 and the low leafstock but does not climb, the switch is good, the equal engine and the switch that carries in the trunk is also good because I tried with another, the cables that leave it to the engine have continuity, the internal relays are fine, but there is no change of polarity for the door of the door when the switch operates. Someone has the cable scheme of the windows or it is also worth knowing what they do the 15 cables of the switchboard connector, and thus be able to solve the inconvenience.
